0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 10 New Guy | | New Guy Joined: Aug 2012 Posts: 10 | Hi Folks, It's been awhile since i was Active here, the reason is mainly due to that my Gmc 270 runs really great, so i have been out driving =)
However, i have picked up a mystery Chevy L6 for almost free, which i would like to ask you kind gentlemen if you might help me identifying what it is.
I Think i know so much that it is either a 194, 230 or 250. I know it is newer than 1963(?) since it has the "standard" Chevy bellhousing (a th350 would fit bolt-on without trans adapter) It also has a spin-on oil filter in front of the fuelpump.
The numbers i have been able to see are: Casting: 348675 (found on rear passenger side block, under this number is GM and under that is "2") Serial: F0507CGT (OR CCT) <- i have been able to work out that it might mean: Flint, May, 07.. but the CGT is a mystery to me.
Also, when comparing the width of the block to my gmc 270, it seems really narrow..kinda skinny, especially the valve cover (which is fastened with 6 bolts btw..)
When googling 348675 i see that some say it's a 69-78 Chevy 250, it would be great if this was the case, for then i am swapping the sbc350 in my hot rod for this one.
Thank you in advance for your thoughts about this.
/ Fred | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | 348675 according to the Chevy Inline 6 Engines 1929-1989 book is a 1973-79 250 CID 100,105 Horsepower 7 Main Caps car motor.
CCT = 1975 Nova, 250 CID, 105 HP, 350 Transmission, L-22 RPO (Regular Production Option), 1 bbl., & Federal Smog equipment.
I did not see a code for CGT
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Aug 2012 Posts: 10 New Guy | | New Guy Joined: Aug 2012 Posts: 10 | Thank you!
This makes sense, so what i have is a 1975 Chev 250, cast in Flint on the 7th of may. | | |
