3 members (Steelonsteel, Patina 54, CandoBrent), 42 guests, and 3 robots.
Topics128,034
Posts1,055,440
Members48,422
#1056885 09/17/2014 8:41 PM
On my 216, I already pulled the head. I want to remove the engine from the chasis. The manual says to use the bolt holes on the head.
Can I use any holes on the block or do I need to put the head back on?
Thanks.
Judson #1056886 09/17/2014 8:42 PM
Any of the head bolt holes in the block would be fine.
My Blog
Judson #1056898 09/17/2014 9:41 PM
Sir Searchalot
Sir Searchalot
Any 5/16 or larger bolt hole with good thread engagement will be OK.
Judson #1057047 09/18/2014 4:07 PM
Don't use a long bolt that will let the chain slide. The chain should be held tight against the block, or head. I have seen head bolts get bent from improper lifting.
Joe
Joe H #1057081 09/18/2014 7:54 PM
Thanks, guys!
