2 members (cmayna, CuzzFuzz), 60 guests, and 7 robots.
Topics128,012
Posts1,055,320
Members48,419
#1055949 09/13/2014 8:18 PM
I am replacing the floor mat (cutting it myself from a 6 foot by 3 foot piece of 1/8" thick mat material) in my 1966 GMC 5500 truck cab and need a shifter boot to finish the job. All I have now is a hole in the floorboard and what looks like the remains of a foam ring between the floorboard and the new process (my guess based on shift pattern) five-speed transmission. There is also a two-speed rear end cable (to vacuum switch) going through the same hole. Does anyone have a suggestion about what to get and where? All I can find are boots for the pickup truck four speed transmissions. The hole diameter is about 4 1/2 inches.
JRMunn
JRMunn #1055982 09/13/2014 11:29 PM
We used to have a '68 GMC dump with the 5speed/2 speed setup and I might recall that the axle cable was strapped to the stick and shared the same hole in a round bellowed boot.
What jumps to mind is one of the "small 4x4" with the transmission stick and T'case stick sharing the same two hole boot.
Anyway, look on eBay for truck transmission boots and I bet you'll find one that'll work.
JRMunn #1057254 09/19/2014 3:01 PM
GM part number is what I used on my 1961 C60. They show up on eBay all the time. Search that part number and look at picture, it has small "X" cut in boot for hi lo selector cable.
Part number 15625828
http://www.ebay.com/itm/15625828-GM-CONTROL-LEVER-BOOT-/231211158152?pt=Motors_Car_Truck_Parts_Accessories&hash=item35d5424a88&vxp=mtr
JRMunn #1057407 09/20/2014 8:35 AM
I fitted a 5 speed to my 47 and the best I found was, I think, a ford pickup 1968 floor change boot. It big, tall, round, looks the part and screws to the floor with a steel reinforced flange.
Plenty of room in it and plenty of flex.
'47 Canadian RHD 1.5 ton truck
4x4toy #1058541 09/25/2014 10:17 PM
4X4,
Thank you for the shift boot lead. I agree that the GM No. 15625828 boot looks like it would work. But I can't find the metal ring that holds it down. Do you know a source for the ring?
I am also unable to get the knob off of the over/under cable, so I am guessing that it needs to come off at the switch under the truck?
JRMunn
JRMunn #1059960 10/03/2014 2:22 PM
Hard to see in picture. It has metal ring on it.
Have not installed my boot yet, I cant help you with disassembly.
