| | | Forums66 Topics128,049 Posts1,055,701 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Well... I went to help a friend move today. Truck ran excellent-for the first 10 miles. Passenger heard a noise,like a tool box door dropping,so I pulled it over to inspect. nothing open,or missing,so I continued driving. when i shifted into 4th,i noticed the clutch slipping,and thought it was odd,it never did that before,and couldn't smell hot asbestos. I continued running good,for another couple of miles,when i heard something like a valve train rattle,(like an over-heated engine. At the same time,my oil pressure dropped to about 20 P.S.I.,from its normal 45. As soon as I got it on the shoulder,I pushed the clutch in,and it "died". I jumped out,looked under the truck,and i had about 1/2 a quart of oil on the ground,and it was running out of the rear main seal area. After letting it sit for a couple of hours,it started right up,and I didn't hear a rod knock,but shut it down immediately,as to not cause further damage. I've heard of rear main seals leaking a quart,every 100 miles or so,but to lose that much oil that quickly?? I have a few spatters on the firewall,but looks like most is coming from the pan/bell housing area. All the FLAPS around here list 235's,but don't show 261 oil seals. Are they the same?? THANKS!! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 235 and 261 use the same seal. To dump that much oil I would suspect too loose of a rear main clearance, or the engine is not vented correctly.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I wonder if the plug in back of the cam fell out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Hope not... Sounds like a complicated fix! Thanks,though! Food for thought. | | |
