2 members (baldeagle, Ponchogl),
69
Mod | | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 43 Junior Member | | Junior Member Joined: Feb 2003 Posts: 43 | Hey All! I need to take the vent glass out of the frame on my 59, am I going to need to take the whole frame apart, rivets and all.
Once again thanks bolters
rebuild not replace
| | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I don't know about the '59 vent glass, but the '54 glass slides right out if you soak the rubber seal between the glass and frame in gasoline. I took the whole assembly out of the door, laid it flat, and poured some gas on. The next day I wiggled it and it popped out. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Gasoline does add a certain thrill to the exercise but I usually use paint thinner or mineral spirits with glass in the earlier trucks. I also don't know if these solvents work with the '59 vent glass.
Tim | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Add a match or two and it will "POP" out real easy
| | | | | Joined: Feb 2003 Posts: 43 Junior Member | | Junior Member Joined: Feb 2003 Posts: 43 | Thanks the thinner worked!
rebuild not replace
