3 members (klhansen, TUTS 59, 1 invisible), 117 guests, and 1 robot.
Topics128,192
Posts1,057,355
Members48,469
#105539 09/17/2003 10:23 PM
Junior Member
Junior Member
Hey All! I need to take the vent glass out of the frame on my 59, am I going to need to take the whole frame apart, rivets and all.
Once again thanks bolters
rebuild not replace
#105540 09/18/2003 4:48 AM
I don't know about the '59 vent glass, but the '54 glass slides right out if you soak the rubber seal between the glass and frame in gasoline. I took the whole assembly out of the door, laid it flat, and poured some gas on. The next day I wiggled it and it popped out.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#105541 09/18/2003 5:59 PM
Gasoline does add a certain thrill to the exercise but I usually use paint thinner or mineral spirits with glass in the earlier trucks. I also don't know if these solvents work with the '59 vent glass.
Tim
#105542 09/19/2003 9:32 AM
Add a match or two and it will "POP" out real easy eek grin
#105543 09/19/2003 3:00 PM
Junior Member
Junior Member
Thanks the thinner worked!
rebuild not replace
