0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,289 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Well I finally got the H02 4:11 in my 59 this weekend and its a happy driver. You can feel the pickup and i think it was worth the work. Next stop Cab.  | | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | I cleaned the engine and primered it! It will get another coat tomorrow (after i get more primer) and paint the day after that! I can't wait until i can see a clean Engine sitting in a my frame! | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | Jockboldter50, Ever since I have had the truck, it's been garage kept. You can tell where the problem spot were at. Thanks for the kinds words on the progress of the truck. If you are ever over in the area, stop on by and maybe we can get a few others in the area to have lunch or something.
Skip, Thanks for the compliment. I got sick as a dog this weekend and didn't finish what I started. It will be forever continuous. I like to see that your truck was put together so fast and is on the road. Good on you.
Props to everyone who has kept this post going. It is enjoyable to read up on and follow along.
Bread .
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Worked on the speedo a little. It'll have to wait now. Spent the rest of the day getting 'big orange" ready for leaving in the AM for the Reunion. All is on go.
..jockbolter, if you make it to Newport News let me know. I'll drive up and make it three of us for a gab. Bread is a super guy. He and family stopped in at my house on his way to Va. | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | I worked on the 54 3100 yesterday after work. Installed two new tail lights, removed the shift lever from the column so I can free it up. Also removed some more debris from the cab. As soon as this shift lever is loosened up it will be time for the first trip around the block. | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | I have been working on the truck's lighting as time has permitted. Headlights: Taken buckets apart, cleaned, shined chrome clamps, new aimers, original T3s. Rebuilt the crudded-up headlight switch. Directionals: Added back an original loud metallic sounding turn signal relay, new cork gaskets, bulbs and clear lenses. Fogs Re-wired fog lights with a proper relay, took the housings apart, cleaned them up. Added in a fog light switch and made an stock looking light-up knob. Brakelights: Took housings apart, cleaned, replaced bulbs, gaskets and pigtails. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Fixed a stress crack i'd conveniently overlooked in the rush to get on the road,it was on the angled bed side section before the bed roll at the rear stake pocket. I'd lightly tack welded it but hadn't gone deep enough,10 minutes with a grinder and subsequent weld has cured the problem. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2014 Posts: 216 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 216 | Ordered some extra rear door hinges for the bus. Figured the price was right & I had the extra cash so why not get them while they stil can be gotten....joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Amazing work and creativity there Steve!!!
~Jim
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Got new trim screws for the missing ones on the window and windshield trim on the '48 Burb. Went to put them in the empty screw holes and found there is no hole in the body to screw into. Modifications were made when the top was chopped 3" and the original holes no longer line up. Out comes the drill and new holes will be my goal. Ordered new full coverage door panels. Now I have a big hole in my wallet.
| | | | | Joined: Dec 2012 Posts: 78 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 78 | Thanks Jim, The one front drum on the truck had a wobble.Indicated by the machine shop, on turning the drums. Sure enough I installed it on the axle and it was spinning in and out. I purchase a new one from Rockauto. The old drum looked good with no grooves. But intill I spun it on the Axle and could see the warpness. Don't take nothing for granted, check all the parts. | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | got the hood stripped of paint! Making progress to priming! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Amazing how addressing a couple of small rattles can radically change driving the truck. My heater (Austin Mini) was rattling due to the foam seal on the 'door' deteriorating,10mins later fixed,part of the seat frame too. What a difference! Who said 'real' trucks rattle?  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Installed a few trim screws in the windshield and door frames. Found out I didn't have long enough screws to finish so ordered more. Also ordered panel screws to install the door panels when they arrive.
| | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Installed my new windshield, rebuilt the carburetor and changed the oil. | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Did some prep work to get ready to install the rear window, removed the hood and drilled out a twisted off bolt,reinstalled and adjusted. Also replaced the shifter bushings and mounted new tires. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You've been staying busy. | | | | | Joined: Aug 2014 Posts: 216 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 216 | Got the rear axle bolted back in, need tires to set it on the ground and started installing my dropped springs & spindles in the front....joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Have to keep chipping away at it everyday. Only way all these projects will get done in one lifetime. | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | I started on my project this last week. Stripped the paint on the first fender: http://ssrjim.wordpress.com
| | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | Ordered a voltage reducer so I can hook up my heater. Replaced the door weatherstripping in the passenger door today and replaced the door glass that got broken by slamming the door with no weatherstripping.---Jack | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Finished installing the trim screws on the windshield molding and door molding. Raised the driver and passenger seat up 3 inches. I'm 6'2" and could not see over the steering wheel. Now I can and it feels more like the proper position. The Burb goes into the shop tomorrow for a complete front end rebuild and a full front/rear brake job including a new master cylinder. More to do at my place when it comes home from the shop.
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Moved my rear axle back 1.5" . . . I don't think I like it. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Well, twotone, move it back.
~Jim
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Well I don't think I'm going to move it back to the stock location (and have to shorten the drive shaft) because I don't like it there either, but I might move it forward a quarter to half an inch.
Just finishing up a T5/open rear conversion and getting tied up on the little things.
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Finally got the drivers Door installed. Yes it lines up and the gaps are even. HAPPY DANCE.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | What's the issue you're facing?
~Jim
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | My only real issue is one of aesthetics. The wheel "centered" in the wheel opening by way of measurement etc. looks out of sorts as opposed to the "too far forward" or stock position. I'll give it a couple weeks before I make the call.
On the bright side I took a short test drive around the block and I do like the T5 and 3.90 rear. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I understand; It's gotta look right. I was using the original gear set that came with the Chevy 10 bolt 2.73 thinking gas mileage would be so much better. I finally switched to a 3.73 and the difference is amazing.
~Jim
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Started working on a patch panel for the front of the DS front fender. | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | Got my right rear fender in to epoxy primer: http://ssrjim.wordpress.com | | | | | Joined: Aug 2014 Posts: 216 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 216 | I repurposed some left over 1950 Chevy 3/4ton frame I had laying in my "Pile O'Metal". We're expanding our back deck & screening it in and I needed some angle iron to support it above the concrete footings. Since I very seldom throw anything away I found a 14" section and cut it down the center to get the two pieces of angle iron I needed. I figured I saved some $$$$$$$$, I recycled an old piece of American Iron, it will serve its purpose & as thick as it is that I would be dead & long gone before it would ever rust/rot away....joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Nov 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 38 | I got the interior of the cab painted the aggie maroon yesterday. With just a little luck I can get the outside of the cab painted today - and then the cab is ready to set back on the chassi. progress. ken | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | How about some pictures Kin?
~Jim
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | Got the rear fender into filler primer today, seven hours: http://ssrjim.wordpress.com/ | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Got the yard dog running today. It hadn't been started since before I started my cancer treatments a year ago. I've been working a little each day since Sunday on it.
Of course the battery is shot. Luckily I had a spare. I pulled the entire fuel system, including fuel pump and cleaned it all. The carb wasn't as nasty as I expected. Replaced fuel with fresh.
Pulled the plugs. They still looked new after I brushed the soot off them. I was running R43. I swapped them for 46x. A little hotter plug since this never gets on the highway.
Also pulled the valve cover to be sure everything under there was moving and getting oil.
It took 2 starts on starting fluid before she got gas to the carb, then she ran sweet. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Got it safety inspection today and it passed!!!
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I found a couple of springs in the driveway last week. I couldn't figure out where they came from. I looked under both my old trucks and the springs in them don't match the springs I found. One of these has rounded ends and the other has 45 degree corners. All my truck's springs have square cut ends. So I assumed they didn't come from my trucks.
Saturday we drove the Suburban to Gordon for a show'n'shine. Took the interstate there at speeds up to 75 and didn't notice anything out of the ordinary. But took the farm roads back and noticed the front end was 'funny' on some of the bumps.
Sunday morning I got under the Suburban for another look. This time I counted springs. The right front was missing 2 and the caster shim. And there was no alignment pin in the spring pack. Apparently the pin had rusted away sometime in the past and a couple of springs lost. The PO found a couple of springs from who knows what and stuck them in there. I have been driving it that way for nearly 30,000 miles.
Last night I pulled a couple of springs, a shim and an alignment pin from a parts truck and put it back together right. | | |
