| | | Forums66 Topics128,100 Posts1,056,178 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 21 New Guy | | New Guy Joined: Sep 2014 Posts: 21 | Just finishing front disc brakes and firewall mounted power booster in my 49 3100. Future thoughts were to add dual 1bbl carbs and split exhaust to the 235 ci engine. Will this fit now? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You'd have to post a link to a picture of what you have.
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | What's the clearance like now,between your power booster,and stock intake? You can almost visualize if it'll fit,or not. The dual intake will have about the same configuration,as the stock. Just find a small box,or something of similar size, to your carb.,set it back,(toward firewall), on your stock intake,and check for clearance issues. They should clear the hood with no problem. Exhaust shouldn't be an issue. Hope this helps! Like Tim says:) Please post a link. | | | | | Joined: Sep 2014 Posts: 21 New Guy | | New Guy Joined: Sep 2014 Posts: 21 | I was a little premature when I said I was almost done. Stopped before I mounted the firewall unit. Hopefully this weekend. I will go ahead with the install then some photos and measurements. I am guessing that the carb centerline is similar to single carb - distance of carb center off valve cover center. Using measurements off future air cleaner diameter I should be able to figure it out.
Thanks for input. Will post more as I progress. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | all I know is things gonna be packed pretty tight in that corner... | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | TX Willie,That's what I'm thinking,too. Best of luck with install! | | |
