2 members (Johnnydog, 78buckshot), 60 guests, and 2 robots.
Topics128,060
Posts1,055,832
#105501 02/16/2003 3:33 AM
Any one ever try naval jelly to remove rust?
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
#105502 02/16/2003 4:10 AM
yep.
works.
one of the oldest de-rusting things around.
also look for liquids with phosphoric acid [NOT pepsi! LOL] - one is called Oxy-Solv.
phosphoric acid is a body shop sort of metal prep that works quite well, but will damage some things like zinc coating and aluminum.
or try the derusting solutions in the 'Bolts tech-tips.
