| | | Forums66 Topics128,037 Posts1,055,469 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | Any one ever try naval jelly to remove rust?
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yep. works. one of the oldest de-rusting things around. also look for liquids with phosphoric acid [NOT pepsi! LOL] - one is called Oxy-Solv. phosphoric acid is a body shop sort of metal prep that works quite well, but will damage some things like zinc coating and aluminum. or try the derusting solutions in the 'Bolts tech-tips.
Bill | | |
