0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | Hello, I am unsure of what kind of rear end I have in my newly acquired 61 apache, and if it is original or not. I took pictures but do not know how to attach them to this post. The numbers stamped on it are MA 10 04. From what I can find from the internet MA is abase axle C14,built 10 month 04 day of the month. Is a C14 the same as a C10? The reason I question this rear end is, I am trying to purchase parking brake cables for this truck(currently there is only the front one which is rusted)and all pictures that I have seen of new rear cables look like the cable is attached to the backing plate with possibly two bolts , where my backing plate only has the one large hole in it. Can someone please give me some direction as? | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | I couls find the PB cable for the cheys from NAPA but the ones for the GMC were not available.
You Learn more Listening than Talking
| | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | Good day HerrOtto. Yes the C-10 is the generic ID for a 1/2 ton. Your C-14 is a short wheelbase, the C-15 is a long wheelbase. Fourwheel drives were K-14 / K-15
The 3 cables are still available from various vendors, advise them as to what wheelbase you have. The rear ones do mount in the round holes in the lower part of the backing plates. You will need to remove the brake shoes to squeeze the "fish gill" retainers on the cable. Have fun with your new found truck. Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | Howie, thanks for the reply. Is there a way I can post pictures on this site. My backing plate has one hole about 3/4" round. Any picture I have seen on internet sites of the cables for my year truck w/shortbed, have a mounting bracket w/two holes in it to mount to the backing plate. My backing plate just has the one large hole. This is why I am wondering if the rear end is not original. I really dislike having a vehicle w/standard transmission and no parking brake, especially when I am having running problems with the truck. Thank you | | | | | Joined: Jun 2010 Posts: 135 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 135 | Check out www.inlinetube.comThey probably have what you need. If not they can replicate what you need if you send an original. John
1964 K10 Fleetside Pickup Truck | | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | Johnnywaz212, thank you for the suggestion, unfortunately I only have the old front cable, no rears. The inlinetube site does not have a picture of the rear cables, so I am unsure if they would be correct or not. | | |
