7 members (52Carl, Wayne67vert, 53 green 1- ton, Otto Skorzeny, 78buckshot, DadsFirstPickup, greenie-reddy), 67 guests, and 3 robots.
Topics128,130
Posts1,056,713
Members48,454
#105452 08/02/2003 9:21 PM
I have a pair of front fenders from the Terminator, they are really rusty at the lower front and rear edges but fairly straight otherwise.
What I need to know is should I save these or save the fender braces and send the rust on to rest?
I thought about repairing the fenders with fiberglass as these will likely only be on a working truck.
Are these a one year only fender?
All thoughts appreciated(even the smart@$$ ones grin )
#105453 08/02/2003 9:34 PM
Luke: I would problay try and save them if its just a work truck, crazy things are high priced I bet. You can always changed them if you decide different.
I hope they last longer than only 1 yr. :p popcorn The Truth is Out There (Go for it)
#105454 08/03/2003 1:30 AM
It is my understanding that the '54/55 Chev and GMC fenders are unique; they have a square indentation for the running lamp housing, which was integrated into the wider grille.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
