Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (farmallb, baldeagle, TGP, 1955 1 Series, Dennys28), 71 guests, and 3 robots.
Topics128,005
Posts1,055,266
Members48,418
#1054134 09/05/2014 12:57 AM
Please don't turn away, I know you fellas could care less if you ever heard of, saw, or talked about another small block 350 swap, but this is a low budget operation. I think I'm putting a 350 in my 1948 GMC 1 1/2 ton. I heard that there might be clearance problems with the steering box/shaft. Is this true? Also, will there be any other issues? Thanks in advance.
I have also hear that there are clearance issues with the steering box... but this would be a great thread for the HiPo shop! They would know much more than a general truck thread!
Small block in an AD......:-( About the only other thing might be the oil pan clearance?? maybe firewall??
This is almost as bad as mentioning the F@#D word.....LOL
I have more zippers then a pair of cargo pants
A lot of folks just move the steering box over about 3/4rds to an inch...joe
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
Small blocks are shorter than the I-6's. There should be room,(maybe not plenty),for distributor,and bell housing. Several recent threads have stated the need for a fan "extension",and radiator shroud,since the V-8-s "sit" farther back from the radiator. Depending on the manifolds used,exhaust clearance may or may not be an issue.Engine mounts,and transmission/bell-housing adapters,are available from several "Speed Shop" vendors. You may want to find an over-drive transmission,or a later model 2-speed rear,because your top speed is still going to be 45-50. And that V8 will be over-revving,which isn't good,on longevity,or fuel mileage. Hope this helps!
Mo' Tater
Thanks for all the help guys. Wetwilly, the rear axle is a 2-speed which I think is original (has lever on floor),and I know that the originals were still geared very low. As far as transmissions go it has a 5 speed which is not original to my knowledge because it doesn't have original shift pattern. I cant find a name plate on the tranny.
48 bigbolt,you MAY be in luck,as far as the 5-speed goes. There are several recent threads on the "Big Bolt" page(s),about the Clark 5-speeds,and the way to tell if they're 5th. direct,or over-drive. Another thread covers the New process transmissions. A friend of mine has a '50 G.M.C. 450 tandem,and it only has a power divider,not 2-speed axles. It has a 4-speed transmission,as well. Makes me wonder if your 5-speed is original,or after-market? Not that knowledgeable about the A.D. Chevy's,or G.M.C.'s., just wondering. I HOPE yours is an O.D. transmission.
Mo' Tater
