3 members (Wheelie, tclederman, Woodcmiami), 113 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#1054071 09/04/2014 6:50 PM
Hello, I just picked up a 61 Chevy Apache. a different fuel tank was relocated to under the rear frame rails. I do not know what the new tank is from. I have no working gauge. The truck also came with the old tank. Do you think I can retrofit the old sending unit into this new tank and get the stock fuel gauge to work?
Test the old sending unit by itself first.
Also see if it's Mounting Flange holes co-respond to the Hole-pattern on the tank you are thinking to put it into.
