| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | Hello, I just picked up a 61 Chevy Apache. a different fuel tank was relocated to under the rear frame rails. I do not know what the new tank is from. I have no working gauge. The truck also came with the old tank. Do you think I can retrofit the old sending unit into this new tank and get the stock fuel gauge to work? | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | Test the old sending unit by itself first.
Also see if it's Mounting Flange holes co-respond to the Hole-pattern on the tank you are thinking to put it into. | | |
