7 members (TUTS 59, homer52, Otto Skorzeny, Youngin' Tut 59, dt235sd, 2 invisible), 122 guests, and 1 robot.
Topics128,052
Posts1,055,727
#1054013 09/04/2014 3:03 PM
Any one know where I can buy a pair of running board step plates for a 52 chev 1/2 t PU? I am scuffing the pint on the running boards when I get in and out
Denny G
Sandwich, IL
Yep Denny, so far my painted running boards are holding up just fine. I don't like the look of the step plates and have heard it causes corrosion. Not to mention the holes that have to be drilled into the running boards that I spent weeks restoring. If mine get scuffed too badly over time, it would be quick and simple task to lay down a new coat of shiny black paint.
I try not to pivot my foot on the running board getting in and out of the cab.
That is why I painted mine with Rustoleum rattle can paint. The hardware always has it in stock for touch ups. I flows really nice and you can't tell where the touch up is.
Carl
Denny,
Your link does not go to a specific part.
Tried to link the page that showed all three at once, dint work, I changed it.
Tks Tim.
dg
Denny G
Sandwich, IL
I put a set of the "type A" plates on the running boards of the 2 ton. I think they look really great on the boards that I coated in black bed liner.
Not only is the bed liner resistant to scratching, it gives the look of rubber covers, which were available for that size running board. And the plates I got were old, so when I polished them up they look just used enough I don't worry about scratching them.
