11 members (Otto Skorzeny, Southerntruck, D B Cooper, klhansen, Peggy M, Jims46, Hawkman, manymiles, MikeE, joe apple, 1 invisible),
100
Mod | | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 15 New Guy | | New Guy Joined: Oct 2011 Posts: 15 | Any one know where I can buy a pair of running board step plates for a 52 chev 1/2 t PU? I am scuffing the pint on the running boards when I get in and out | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Yep Denny, so far my painted running boards are holding up just fine. I don't like the look of the step plates and have heard it causes corrosion. Not to mention the holes that have to be drilled into the running boards that I spent weeks restoring. If mine get scuffed too badly over time, it would be quick and simple task to lay down a new coat of shiny black paint.
I try not to pivot my foot on the running board getting in and out of the cab. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | That is why I painted mine with Rustoleum rattle can paint. The hardware always has it in stock for touch ups. I flows really nice and you can't tell where the touch up is. Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
Your link does not go to a specific part.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tried to link the page that showed all three at once, dint work, I changed it. Tks Tim.
dg
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I put a set of the "type A" plates on the running boards of the 2 ton. I think they look really great on the boards that I coated in black bed liner. Not only is the bed liner resistant to scratching, it gives the look of rubber covers, which were available for that size running board. And the plates I got were old, so when I polished them up they look just used enough I don't worry about scratching them. | | |
