7 members (Gdads51, joe apple, 78buckshot, Hanks custodian, Otto Skorzeny, 1955 1 Series, Rexville48), 122 guests, and 2 robots.
Topics128,070
Posts1,055,896
Members48,428
#1053816 09/03/2014 5:40 PM
Have a 59 chevy apache 3100 with original 235. Lately I have noticed the oil pressure was really low, even when revving engine hard, may only get in mid 20's of pressure. I read the manuel and it wasn't much help. Will changing the oil pump be the solution for the oil pressure situation? Am also getting noise out of the bottom end of the motor, its been there ever since I had the head rebuilt due to oeverheating. Need some help here. Thanks.
Does it hold mid 20s oil pressure when warm and at 2000 RPM?
What is the oil pressure when at idle and a warmed engine?
Noise out of the bottom end might be associated with worn bearings. That might be associated with lower oil pressure.
yes, it does hold that oiul pressure when warm and engone is revved. Not sure of the RPMs, the pressure is sub 20 when idle and warmed up. We used an aftermarket oil pressure gauge, but do not have a guage to measure rpms.
Like Tim said,check,(plastigauge)your rod and main bearings. You may need to have the crank ground,too,depending on wear. Good luck!My '55 261 has about 50# cold,and about 40# warmed up.
Mo' Tater
I wouldn't run it much until you check things out. If you had a head gasket failure and dumped antifreeze into your engine it could have scuffed the bearings. Antifreeze is corrosive to bearing material.
thanks for the advice. Had my mechanic take a look, he said everything looked good on the inside, going to replace the oil pump and hope for the best!
