7 members (Hotrod Lincoln, Oldcaliforniakid, 49nut, frogfarmer, Stovebolt48, mason86, Woodcmiami), 89 guests, and 1 robot.
Topics128,050
Posts1,055,671
One look under the cab and it becomes apparent that the bench seat base in the AD trucks double as a structural floor support.
For a street rodder who wishes to replace the bench seat with buckets, center console, etc., the stock seat base/internal floor support is obviously undesirable.
I would love to hear from you and see pictures of any modifications you may have done to replace or work with the stock seat base.
Thanks!
1 Offline
I started from under the floor and restructured the floor supports and front body mounts. My front seat is actually a rear late model suburban seat. So my seat needed a riser to accommodate the tranny hump that was in the burb. The riser is just for leveling my seats , as they sit high enough for me and I am fairly short.
seat pics
So I gotta ask: The "pucker" mark on the passenger seat, that from a shared test drive? Bet that passenger won't come back for the next test..:)
Steve H
High speed clenching from the ole lady, I'm betting.
1 Offline
There was a head light bucket set there for about a week. My wife is scared to ride in my hot rods. The last time I got her to ride with me on something I built was my motorcycle. I have been clocked @ 206 on that bike. I think with her we have gone above 150... talk about clenching....
I have more zippers then a pair of cargo pants
I have the opposite problem, I am scare to _ _ _ _ to ride w/Denise & when I HAVE too I ride w/my eyes closed....joe
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
JerryV,
What year and body/cab style truck.
Standard cabs, COE cabs, panel-truck, canopy-express, and carryall-suburban cab-floors and seat-frames are different.
JerryV,
It is a 51 gmc 1/2 ton with the corner windows.
I took a look at several possible donor seats and I think the best bet for me is to first locate the seats I will use and then figure it out. There are so many different seat designs that some might actually fit right on top of the factory base.
Jerry:
Mine is a Task Force truck, but maybe this gives you an idea for yours. I installed two buckets from a 2006 Audi and a custom center console.
I built an intermediate mounting frame that was bolted to the truck (making sure to use the original anchor points). Then the sets were mounted to the intermediate frame. I used 3/4" rectangular tubing. If I ever go back to the original seat, it is a simple swap since nothing was changed on the floor anchoring points (they are used to mount the intermediate frame).
don
