7 members (Bill Hanlon, Otto Skorzeny, TexasA&M48Truck, John L., 55shaker, Wally / Montana, Uncles51),
96
Mod | | | Forums66 Topics128,075 Posts1,056,003 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | Have any of you traded out the 3 speed for a four on the floor? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 1st or 2nd series? always specify the year .... likely someone has done it, both trans available most years, probably needs a longer driveshaft cuz the 4 speeds are shorter
Bill | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | This is a first series pickup. The transmission pops out of gear. I figure if I'm going to go through the trouble of pulling it I might as well put in a four speed. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you do know that any 4 speed high gear is still 1:1? and the original style SM420 has a wall climber granny low you'll never use? less trouble to R&R the 3 speed than make modifications to get an extra gear for 'show'
Bill | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | on my 54, I did this swap. I didn't do it for any "upgrade". As Bill said.... the final gear ratio is the same at 1:1. I swapped motors to a 230 and just did the tranny at the same time. I MAY use my granny gear in the future pulling a small trailer. So I went ahead and did it. Plus, I had it available.
If you're looking for better performance.... skip it and go with something else. If you have the 4 speed readily available for super cheap, go for it. But I would still repair your 3 speed and put that back in... its got the cool factor, and you dont see them much ever anymore. | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | Ok, I'll look into re-building it. I did find a four speed for $75, that was the reason I was going to swap it. | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | I was going to do this swap at some point. I was just doing it to get a floor shifter though. I already have the 4 speed but know I'm considering going with something a little newer like a t5 with OD and full synchronization. | | |
