7 members (Forty9, fonz8261, jkreiner, treegrower, Bill Hanlon, Wally / Montana, TexasJim50), 51 guests, and 0 robots.
Topics128,074
Posts1,055,914
Members48,429
#1053682 09/03/2014 3:29 AM
Have any of you traded out the 3 speed for a four on the floor?
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
1st or 2nd series? always specify the year .... likely someone has done it, both trans available most years, probably needs a longer driveshaft cuz the 4 speeds are shorter
Bart #1053748 09/03/2014 12:37 PM
This is a first series pickup. The transmission pops out of gear. I figure if I'm going to go through the trouble of pulling it I might as well put in a four speed.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
you do know that any 4 speed high gear is still 1:1? and the original style SM420 has a wall climber granny low you'll never use? less trouble to R&R the 3 speed than make modifications to get an extra gear for 'show'
Bart #1053884 09/03/2014 11:23 PM
on my 54, I did this swap. I didn't do it for any "upgrade". As Bill said.... the final gear ratio is the same at 1:1. I swapped motors to a 230 and just did the tranny at the same time. I MAY use my granny gear in the future pulling a small trailer. So I went ahead and did it. Plus, I had it available.
If you're looking for better performance.... skip it and go with something else. If you have the 4 speed readily available for super cheap, go for it. But I would still repair your 3 speed and put that back in... its got the cool factor, and you dont see them much ever anymore.
Bart #1053898 09/04/2014 12:41 AM
Ok, I'll look into re-building it. I did find a four speed for $75, that was the reason I was going to swap it.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Bart #1053989 09/04/2014 11:00 AM
I was going to do this swap at some point. I was just doing it to get a floor shifter though. I already have the 4 speed but know I'm considering going with something a little newer like a t5 with OD and full synchronization.
