2 members (crenwelge, 1 invisible),
181
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | I've searched Ebay and Craigslist looking for used split rim 15" / 8 hole rims because I need two to get the rear wheels back to stock. I read Jim Carters page on this subject and others. The more I read, I start to become concerned for safety and the ability to get affordable tires. I read that there is an issue with clearance on the front wheels due to the tie rod clearance. What options are there that don't require changing the tie rod? How have you 3/4 ton owners solved this?
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This topic comes up quite often. Here is one of the threads that has some answers for you. 8 lug wheels I use the modern 16" rims from the eighties and trailer wheels. I have modern 16" tubeless radials on mine and they work really well. | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Thank you truckernix, this really helps!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Aug 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 50 | I have a 1948 3/4 ton and replaced the split rims with 8 lug 16 inch rims from etrailer. With radial tires 215/16. Those rims have a small amount of positive offset and on my truck clear the front tie rods by about 1/2 inch. I have driven it about 1000 miles without any problem . | | |
