Brrrr
place holder
5 members (1954gmc9314, Hotrod Lincoln, greenie-reddy, 1955 1 Series, Wheelie), 120 guests, and 3 robots.
Topics128,271
Posts1,058,417
Members48,485
Anyone have any info on changing from drum to disc economically?
I've been researching & it appears that '73-'87 1 ton 2wd stuff will swap right over.
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
a.d., you have it right, but 1 ton or 3/4 ton will do. Swap the whole front end to make it easy.
Timely question can I take it back a few years?
A buddy of mine has a 1959 1-ton behind the barn that he always tries to get me to take. I'd like to take on another truck but working on a 1950 1-ton I've found that it is tough to find parts and conversion kits to make it more drivable.
Is there an economical way to put front disk on a 1959 1-ton?
Thx -
I have seen a couple of the changeovers on the 67-72chevytrucks.com site and I know a guy locally put a 78ish one under his 70. From what I have seen and read, the frames are the same dimensions from early 60's to 87 for 1/2 tons and 91 for one tons(square body only). I believe there are some holes to drill and an adapter to mount the power steering box but there was a guy making and selling those on the 67-72 site above. They have a wider track width so many will also install the later rear as well as it is wider also unless you get a cab and chassis which has a narrower rear closer to the older trucks. Many have put the later rear in regardless because factory gear ratio on 50's and 60's one tons are around a 5.14 ratio and the later rears are usually 4.10 or 4.56 so that makes them much more highway friendly and repair parts are usually easier to find.
JC Offline
My 66 3/4 ton took a 78 3/4 ton front suspension very easily.
JC in KC
"The future will be better tomorrow." Dan Quayle
1965 Chevy C10 Long Fleetside
Thanks for the info. This website is great
Thanks Again....
Moderated by  Dusty53
