1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | I'm working on the doors of my 50 3800 today and notice that the passenger side latch is shot. It looks repairable but with new latch prices around $35.00 replacing might be the easier route.
I noticed on Carter's site he sells latches for 52-55 doors. Is there a dramatic difference between the 52-55 latches and the 49-51 latches? Do the newer latches work better? I'm assuming the strike plate is different but those are cheap. Easy swap? Or am I opening a can of worms that will stink-up the garage?
Thanks - Bruce | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 47-51 latches work with turn-down exterior handles - the 52-55 latches work with the push-button exterior handles.
I have found that it is a good idea to replace the latches and catches as a pair, at the same time - they match each other better than a new piece matching an old piece.
| | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Ah. Well I prefer the turn-down exterior handles better than the push-buttons. Sounds like I might have to make a run to my local junk yard. They're getting to know me too well over there.
Thanks for the info Tim.
Bruce | | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 |
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | The two latches have different mounting hole locations in the doors. Can't just swap out a 51 into a 52.
