4 members (DadsFirstPickup, Gray_Ghost, cspecken, 1 invisible), 178 guests, and 5 robots.
Topics128,087
Posts1,056,112
Members48,434
#1053233 09/01/2014 5:33 AM
I got a line on a 1957 261 from an apache and would like to know if it would fit in place of my 228 in a '53 GMC. Anyone done this and if so, could I adapt the present 4 speed tranny to run off the 261?
ff171 #1053256 09/01/2014 12:25 PM
Use your 1953 GMC clutch housing and rear motor-mounts with the 261.
If the 261's flywheel to crankshaft bolt-pattern matches the pattern on the 228, you could use either flywheel and the clutch assembly that goes with that flywheel.
If both clutch assemblies have the same clutch size and pressure-pate bolt patterns, you cold use either assembly.
Someone else will comment on the front motor mount. The lengths of the blocks are different.
You might have to "fiddle" with the throttle rods.
ff171 #1053294 09/01/2014 3:44 PM
3B Offline
Hy ff171, you will have to use the 261 flywheel, but as tclederman says use the bellhousing from your 228 that will put the engine in position, but you will have to fabricate something to support the front of the engine, Chevy engines are a bit shorter than GMC engines. I assume this was originally an American truck, as our Canadian light trucks were Chevrolet powered, hope that helps.
