| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2014 Posts: 33 | I got a line on a 1957 261 from an apache and would like to know if it would fit in place of my 228 in a '53 GMC. Anyone done this and if so, could I adapt the present 4 speed tranny to run off the 261? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Use your 1953 GMC clutch housing and rear motor-mounts with the 261.
If the 261's flywheel to crankshaft bolt-pattern matches the pattern on the 228, you could use either flywheel and the clutch assembly that goes with that flywheel.
If both clutch assemblies have the same clutch size and pressure-pate bolt patterns, you cold use either assembly.
Someone else will comment on the front motor mount. The lengths of the blocks are different.
You might have to "fiddle" with the throttle rods.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ff171, you will have to use the 261 flywheel, but as tclederman says use the bellhousing from your 228 that will put the engine in position, but you will have to fabricate something to support the front of the engine, Chevy engines are a bit shorter than GMC engines. I assume this was originally an American truck, as our Canadian light trucks were Chevrolet powered, hope that helps. | | |
