4 members (Otto Skorzeny, klhansen, Shaffer's1950, Steelonsteel), 101 guests, and 2 robots.
Topics128,113
Posts1,056,618
Members48,450
V
V Offline
The 3rd gear synchros have given up the ghost in my '57 Chevrolet 6 cylinder. I replaced the original 3 speed with an original R10 borg warner from another '57.
Where would you guys recommend as the best place to buy a kit to rebuild this transmission? I have no idea how to do this but from what I have researched there are detailed instructions online and I'd like to try to tackle it myself.
I'm not sure that you can buy a "kit" to rebuild your transmission. I would recommend taking it apart, cleaning things up and then examine the parts and start sourcing parts based on what you need. Most vendors can help with basic stuff. You can place an ad in the "Parts Wanted" section also.
V
V Offline
I accidentally posted this in the engine section. Sorry about that, it took me forever to find it.
Thanks for the info. I'll repost this in the appropriate place as well.
The 2-3 synchronizer assembly is sold as a unit, but it might be possible to just replace the brass blocker rings if the steel shift collar isn't badly worn. Try Todd's Auto Parts on 1st. Avenue North in Nashville. They sort of specialize in old stuff, so if they don't have what you need they can probably steer you in the right direction. While you're there, ask about a "small parts kit" that includes thrust washers, needle bearings, and other stuff necessary to freshen up a tired transmission.
I have the non-OD version of that transmission, and I'd be willing to part with it for a reasonable amount, or maybe some kind of horsetrade. I believe everything ahead of the OD unit is identical, including the synchro. Drop me a PM.
Anaheim Gear here in So Cal was a source for the syncros a couple of years ago but they no longer have them. I get bearings and seals from them and an occasional shaft but that's about it. I rebuild a lot of OD transmissions and my best source is finding regular gear boxes at swap meets and Craigs List to use for parts. There are other wear points for the popping out of third gear problem as well. Worn 2-3 shift fork and the engagement spring on the clutch gear are also problematic. Jerry's offer is probably a good way to go.
Fred
V
V Offline
Thanks guys. I'll respond in the other forum since it's the correct location for this thread...
