| | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | The 3rd gear synchros have given up the ghost in my '57 Chevrolet 6 cylinder. I replaced the original 3 speed with an original R10 borg warner from another '57.
Where would you guys recommend as the best place to buy a kit to rebuild this transmission? I have no idea how to do this but from what I have researched there are detailed instructions online and I'd like to try to tackle it myself.
Thanks | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'm not sure that you can buy a "kit" to rebuild your transmission. I would recommend taking it apart, cleaning things up and then examine the parts and start sourcing parts based on what you need. Most vendors can help with basic stuff. You can place an ad in the "Parts Wanted" section also. | | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | I accidentally posted this in the engine section. Sorry about that, it took me forever to find it.
Thanks for the info. I'll repost this in the appropriate place as well.
Thanks, | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | The 2-3 synchronizer assembly is sold as a unit, but it might be possible to just replace the brass blocker rings if the steel shift collar isn't badly worn. Try Todd's Auto Parts on 1st. Avenue North in Nashville. They sort of specialize in old stuff, so if they don't have what you need they can probably steer you in the right direction. While you're there, ask about a "small parts kit" that includes thrust washers, needle bearings, and other stuff necessary to freshen up a tired transmission.
I have the non-OD version of that transmission, and I'd be willing to part with it for a reasonable amount, or maybe some kind of horsetrade. I believe everything ahead of the OD unit is identical, including the synchro. Drop me a PM. Jerry
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Anaheim Gear here in So Cal was a source for the syncros a couple of years ago but they no longer have them. I get bearings and seals from them and an occasional shaft but that's about it. I rebuild a lot of OD transmissions and my best source is finding regular gear boxes at swap meets and Craigs List to use for parts. There are other wear points for the popping out of third gear problem as well. Worn 2-3 shift fork and the engagement spring on the clutch gear are also problematic. Jerry's offer is probably a good way to go. Fred
| | | | | Joined: Jul 2009 Posts: 90 Shop Shark | | Shop Shark Joined: Jul 2009 Posts: 90 | Thanks guys. I'll respond in the other forum since it's the correct location for this thread... | | |
