Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, 1 invisible), 35 guests, and 2 robots.
Topics128,005
Posts1,055,264
Members48,418
#1052658 08/29/2014 11:38 AM
I
I Offline
Wanting to order some engine parts today and not sure what I have. 1950 11/2 ton it is origenal motor. I have heard 235 or maybe 260something.
iceman4 #1052663 08/29/2014 12:35 PM
Your best bet is to get the numbers off the pad on the engine block that is next to the distributor. Your truck could either have a 216 or 235.
iceman4 #1052664 08/29/2014 12:37 PM
In 1950, it would have been a 216 or, more likely, a 235 (if you still have the original engine).
Find and post here the Engine Serial Number that is pressed into the block just to the rear of where the distributor goes into the block.
iceman4 #1053001 08/31/2014 5:13 AM
235 was standard in all 6000 series 2 ton 16000lb. gvw trucks, but yours being a special order 15000lb. 1 1/2 ton 6400, it could possibly have a 216 in it. best to get the engine casting number on the passenger side of the block, plus the eng. id number from the flat ledge, at the base of the dist. shaft, where it goes into the block.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
