1 members (baldeagle), 142 guests, and 2 robots.
Topics128,037
Posts1,055,467
Members48,424
I
I Offline
I am pondering way in advance what not to do regarding my patch panels.
What did you screw up, then have to redo and screw up again?
What will you differently next time?
What part was a total nightmare?
I know some of you can do this stuff in your sleep but I was hoping everyone could tell about someting they learned that they had not read somewhere else.
Sean
An example I keep seeing in my head.
The cab mounts dont line up after floor replacement or something like that and how do you fix.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
Trial fit everything and spot weld everything together first. Take your time, especially when welding and grinding sheet metal. Measure a hundred times, cut several times.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Anonymous
Unregistered
Anonymous
Unregistered
I can't say I have made any serious errors in doing the 16 or so different patch panels on my 54 AD but the tools and the technique are the key. You definitely need a right angle grinder with a good grinding disc and also metal cutoff discs. A wire feed welder is also a requirement and I found that the klecko klips were a great asset to have when fitting panels together. I got my set at Harbor Freight and look forward to the next time I can use them (not really).
Another key is to fit the panels in place and adjust until they fit just right. Patience is a definate requirement.
Also, do not be afraid to cut a panel, reshape itand reweld it to make it work for you. I had to do this to the inner-to-outer panel on one side as it just would not work. Do not worry too much about how a panel or your welds will look to others as we will be in awe of your talent regardless.
And another thing is to be patient when welding or you will warp it although body putty does wonders in hiding such things.
Do a little at a time and it will get done eventually.
That's whole reason I keep my site running. Do it right - not like me.
http://chuckthetruck.homestead.com/page1.html
Anonymous
Unregistered
Anonymous
Unregistered
The Chuck the Truck has helped me several times during my project. It is a great resource and I thank you for keeping it out there.
Z
Z Offline
Brace and support every way possible BEFORE cutting anything lose that would allow any racking of the cab. Especially the cowl panels, rockers and cab corners. Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
Yes, the Chuck the truck website really got me going on my project. It is probably the best material on this that I have seen. And to boot, that pretty truck is not a trailer queen, but a daily driver!
1951 1 Ton Completed
Anonymous
Unregistered
Anonymous
Unregistered
I did learn a valuable lesson over the weekend while trying to refit the doors to the cab. The lesson is to always prefit either cowl or cab corner panels in place with the doors mounted in place.
Oh well, so much for thinking I was done with the darn cab.
