Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (TUTS 59, Mike B), 126 guests, and 3 robots.
Topics128,283
Posts1,058,504
Members48,490
I have a 55.2 that I installed an aftermarket booster/MC into and a different seat. I'm having a disagreement with the supplier about the stock pedal height. Can someone get me the vertical dimension from the floor to the center of the pedal pad and also the horizontal from the point where the toe board and firewall meet? My pedal is way to high.
I got 9" from the floor to the center of the pedal pad, and 10 1/2" from the firewall/toeboard junction to the top edge of the bottom of the pedal pad. Mine is still setup with the stock type master cylinder and pedal.
Bill Burmeister
Thanks....I have 9" from the floor and 14" from the toe board/ firewall. They are telling me t's the same as stock.
turbo, if it's stock height above the floor, sounds like the pedal is "curving out" too much, isn't there any adjustment?
Sir Searchalot
Sir Searchalot
Need to know type of kit. Is this kit the kind that uses the orig brake pedal arm or does it include the pedal arm? Is it an undercarriage/frame mount or a firewall mount? The kind that mounts to original MC bracket, and uses the orig pedal arm, are fixed position and accurately located kits. This is the type I have used several times on TF with good luck.
It's the CPP booster/MC/pedal assembly. The height from the floor is ok. It's the horizontal distance from the firewall that's the problem.tgere is no adjustment but the arm does curve at the bottom and it looks like it would be perfect if it just went straight.
Sir Searchalot
Sir Searchalot
The only kit I've used is 5559BB2. Sounds like you have under dash/firewall unit. Pedal should match clutch pedal if you have one. Is there not a stop adjustment for the up position/brakes off position? It sounds like pedal coming up to high. Check to see what stops pedal, linkage length, a mechanical stop...? I guess I'm asking the same question and comment as Bill already did.
The only adjustment is the pushrod. I turned it all the way down and it lowered the pedal about an inch but it needs to go some more. I may just cut off the bottom of it and weld on a nice wide GM power brake pedal.
Sir Searchalot
Sir Searchalot
Roger
Moderated by  ndkid275, Phak1
