1 members (Naturalthud),
110
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | I've spent the better part of the last two days trying to bolt on my running boards and front fenders on my 38. Nothing seems to line up properly but I think it's pretty close now. Sure hope the hood lines up okay. Anyway, my question is, how much of a gap should there be between the cowl and the aft end of the front fender? When I push the running boards all the way inboard I still have a gap of about 3/8". Is this normal, and is there supposed to be a seal or something in the gap? Thanks for any help, Happy Thanksgiving to all, Don | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Sorry for the delay...
Until someone comes along who really knows the answer, I'll take a stab at it based on my experience with my '39 ground up resto... Did you use welting (seals) on your fenders? If not, using them might take up the slack. If you are using them, then monkeying around with all the parts migyht also do it.
ON my truck, reassembling the front end seemed fairly idiot proof, so if you are having alignment troubles, it may be something fairly simple (hopefully). Remember, though, I'm basing this gained in restoring ONE truck (um, 12 years ago...)
Anyone else?
Thanks, JOhn
~ One of many.
| | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Hi John, thanks for the reply. I did use fender welting around the area between the fender and the front shroud where the fender bolts directly to the shroud. In the area between the cowl and the fender the gap is too great for welting, it's actually about 1/2" on both sides. Oh how I wish I could see a picture or a real completed truck so I could have a better idea of what to expect.
Thanks again, Don | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Raised the tarp on my 38 1 1/2 ton. the welting is still in place on the front of the fenders but missing on on the rear. the bottom of the rear of the fender is tight to the cab at the top it is about a 1/4 inch out. I just figured that was from wear and tear during it's life as a farm truck .The farmer apparently wasn't real careful with the fenders. Thanks to mother nature dumping more rain last night truck is now in a puddle or I'd crawl under and see if any welting was visible on the underside of the fenders | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Have you tried loosening the front fender supports that bolt to the radiator frame ? Just a thought. | | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Thanks to all that replyed to my question. The front fender bolts are loose, will tighten them after rear of fender is tightened. I guess there is supposed to be some gap at the rear so I will live with that. May put in a bulb rear seal to fill it in a little. Patience, patience, patience, wish I had more of it!
Thanks again, Don | | | | | Joined: Oct 2002 Posts: 52 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 52 | I checked my '38 this evening (it has fiberglass front fenders for now) and it has a good 1/4" - 3/8" gap between the fenders and the cab cowl yet the fenders are fastened correctly to the running boards. There are no rub marks on the cowl to indicate they have ever touched since they were installed.
Life's short - don't waste it.
