1 members (klhansen),
90
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | I replaced the 4sp granny low with a new process a833 (rpo my6) on my 53 3/4 ton. I replaced the 5:14 rear with a 4:11 and had a one piece open drive shaft made for it. the trans has a pad under the tail cone that would sit on a cross member support if there was one on my truck.
my question is should I put one in or just let it hang like the old one did?
thanks rolf
1963 c10 | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Yes go with a trans crossmember especially now that you've made a long driveshaft. Make sure it's balanced, these things can go crazy if out of balance. Don't know the max length for a driveshaft but do know if she's to long can cause catastrophic failure. Be safe | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If your bell housing has the side feet mounts, it is typical to cantilever the trans. The bell housings I've seen on that tranny do not have side mounts. If no bell housing mounts, you need cross member tranny support. As you can tell, this tranny was made to be supported like an automatic is. Three point install, two motor mounts and one tranny. You can use a universal, tubular, adjustable cross member sold by many vendors.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I guess I'm overly concerned as this is a 3600 came with a two piece drive shaft. A friend of mine totalled his 3600 after swap to long one piece driveshaft. The front u joint gave up and it pole vaulted off the side of the road. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Jim/Rolf, put a sturdy U-shape 'safety strap' under the front of the driveshaft, like a race setup
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 125" WB for 1953 3600 is same as after Chevy went open. I think the 55 1st series standard 3600 had one piece open driveshaft. With proper/same size Ujoints/propeller shaft as they had, don't see a problem. The 55.2 3600 had one piece open. WB is a tad shorter. I had a drive shaft break at about 40 MPH, it can be real dangerous if the front goes. Safety strap won't hurt a thing. You must pay attention to pinion angles with all these swaps.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Yes.....a driveshaft safety loop will prevent the pole vault. I've witnessed that before. I've also experienced a front ujoint retaining clip failure at 90 mph. Man it shook so bad it broke my cast iron bell housing and broke two ears off my Muncie 4 speed. There was " a whole lotta shakin goin on" | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks guys. what does a safety loop look like? where does it go? the bell is the same one that was on the 216 I swapped for the 235. the trans has the std chev 4 bolts to the bell. i'll put the support in too.
thanks again rolf
1963 c10 | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | rgie, here's what some different styles look like. If you had the right tools, you could probably make one pretty cheap out of some scrap steel.
Brian http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?storeId=10001&catalogId=10002&langId=-1&Ntk=all&Jnar=0&itemPerPage=60&Ne=1%2B2%2B3%2B13%2B1147708&searchTerm=deive+shaft+loop
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | |
