| | | Forums66 Topics128,120 Posts1,056,649 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | That's an interesting article. I remember Junior Johnson running away with the 1963 Firecracker 400 with one of the Chevy "Mystery engines", and then every Chevy in the race blew up within about 20 laps of each other. Some of our friends in the race business told us later that a postmortem on the engines found sheared-off oil pump drives on all of them. Too much oil pressure! Those were the Mark II engines he talks about, 427 cubic inches. Jerry
| | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | I think Howell is a little off on his dating of the "flow box" for head work to the 80s. I was running a flow box in the 60s. Also, we used high speed photography to record valve train motion. Had a mechanic that made plastic cockpit covers during the war, and he made things like plastic rocker covers for us.
I can't recall Bill Howell, but I did do some projects with Vince Piggins. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | That was interesting, thanks for sharing.
-W | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Good article. John, thanks. Would have been a gear heads' dream to work on designing those engines.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
