Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Ed Atkisson, TUTS 59), 46 guests, and 5 robots.
Topics128,010
Posts1,055,299
Members48,419
#105151 04/14/2002 7:35 PM
How do you treat the rust that forms between seams that are spot welded together, like roof panel is attached to the windshield channel? I can sand the outer surfaces but how do you prevent the rust between the 2 pieces of metal from creeping back out?
#105152 04/14/2002 11:14 PM
the guys on one of the hot truck tv show welded up the seams grind and finish with lead
i thinkzz traveling along at terminal velocity will soon wear a body out.
i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
#105153 04/16/2002 4:59 PM
Junior Member
Junior Member
Welding up the seems on the cab sounds like a fix for the rust problem. Would sandblasting and metal prep stop the rust prior to welding??? Getting a smooth finish would be another issue, how about bondo?
#105154 04/17/2002 10:25 PM
You could apply zero rust or por15 or something like it to the seam and then just paint over it if you want the seam to show. Don't bondo over rust, it will come right through. If you are going to weld you have to get the rust off first to get a good bead. It will keep the rust from coming through (but you probably want to protect the back of the seam too)
Paint & Body Shop moderator
#105155 04/18/2002 3:19 PM
The problems seams are where the top outside panel joins the windshield frams and cowl joins the fire wall. Both are lap, or one piece of metal laying over another and then both are spot welded together. Rust in question is coming from between the 2 pieces of metal. I have some of the rust stop chemicals from Eastwood. Short of cutting spot welds to get at rust, are chemicals seems like the best solution?
