2 members (Gdads51, ndkid275), 189 guests, and 1 robot.
Topics128,048
Posts1,055,539
Members48,424
#105138 01/02/2004 7:00 PM
Can i prime fiberglass fenders with epoxy primer ?
47.5 Loadmaster 5 window
48 Chevy 3600
69 GTO convertible
#105139 01/03/2004 8:30 AM
Yup. Are you using just rattle can or a 2 part mix up primer in a gun? It also depends on what kind of top coat you are going to put on. Some people sez all primers compatible with all paint, but, in my experience, taint the case. I have had problems with paint lifting on rattle can primer.
If you are using rattle can - I like the DuplColor products as they have a fan spray head and you can almost lay the paint on as good as a gun.
#105140 01/05/2004 1:57 PM
thanks for the info. I am using dupont colar. Have not decided on paint yet.
48 Chevy 3600
69 GTO convertible
#105141 01/06/2004 5:26 AM
Anonymous
Unregistered
Anonymous
Unregistered
You will never get paint to stick to fiberglass be it primer ,sealer or top coat unless you use a flex agent catalyst.
Just tell the paint shop you are painting a jet ski to get the correct chemicals.
#105142 01/06/2004 5:42 AM
Bondo Artiste
Bondo Artiste
Flex agent does not promote nor hinder adhesion. For the longest time in our shop we used a flexing agent, but have sinced stopped and no adhesion issues have come up. We spray only Dupont products.
That is just my experience.......
~ Phillip
#105143 01/06/2004 5:56 AM
Anonymous
Unregistered
Anonymous
Unregistered
After painting many many fiberglass boats & jet skis, we have had the best luck with using paints with a flex agent. Fiberglass expands & contracts way more than steel. If you put a hard catalyzed paint [ without a flex agent ] on a material that expands & contracts like fiberglass does you will get lifting & cracks.
Epoxy paint has a unique property of being more brittle than lacquer or enamel
The same applies for paint on AD steering wheels.
We like to use the " House of colors " line of paints.
