7 members (1955 1 Series, Lightholder's Dad, 55shaker, DuckRancher, Jon G, TexasA&M48Truck, 1 invisible),
70
Mod | | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 60 | I picked up a 1955 Cameo and I thought you could NOT tell if it was a Cameo or not from the vin?
I would like to know if there was a trim tag of some type on them to distinguish if it's a real Cameo truck?
Thanks | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | There does not seem to be a way to use a Vehicle Serial Number to distinguish a 1955-2nd series Cameo 3124 from any other 1955-2nd series 3100 truck. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no way at all to tell, except some year[s] had the 3124 fender emblem, maybe just 57?
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | But, that emblem could be placed on a non-Cameo truck?
| | | | | Joined: Nov 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 60 | Thanks, that's what I thought also. I had checked into this before and got the same answer, but the guy had me questioning myself. | | | | | Joined: Feb 2012 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 112 | The 55 and 56 i believe chevy trucks were available with a cameo option. As such they are not noted in the VIN nor on titles.. they were a 3100 model truck. In 57 they became a model (3124) and were noted as such in VIN and titles.
Old Truck addict 1950 chevy 1 ton napco 1956 gmc 1 ton dually napco 1954 chevy 3/4 ton napco 1957 gmc civil defense napco panel
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | dirtball, maybe you have pictures of vin tags and titles that support that? the FAM [actually a 55 document] shows Cameos as model 3124 from the beginning, and they were until they were discontinued in mid-58, regular pickups are model 3104, but there is no exact model info in the factory vins, any 57 pickup has a vin starting with 3A, and AFAIK 57 was the only year for the emblem saying 3124 - also I've never seen a title with the model number, titles just say 'pickup'
Bill | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | The 1955.2 was the first year for the Cameo Carrier, Model 3124, as Tim posted above. All 3100 series, 1955.2, are H255 which makes it difficult. A factory installed vin tag for the 55 Cameo, should at least be H255. There were a little over 5000 or so produced in 1955. http://auto.howstuffworks.com/1955-1957-chevrolet-trucks4.htm
-Tom
1950 Chevy 3100 w/ 1956 235
