6 members (Otto Skorzeny, walter74, 55shaker, Ponchogl, cmayna, Shade Baby), 212 guests, and 2 robots.
Topics128,114
Posts1,056,282
Members48,439
#1051214 08/22/2014 11:45 PM
Another newbie question. How is the clutch housing removed. Where are the bolts?
What is it your working on Dave?
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
If you are referring to the bell housing, you will need to drop the flywheel (not on your hand, it is heavy). Two on the top are accessed from the rear. Two on the bottom are accessed from inside of the sheet metal flywheel cover on the bottom.
Carl
DaveBP,
As asked above, what year and engine?
Carl.
Many people use the term "bell housing" but that term was not used by GM in regards to 47-55st trucks - the term "clutch housing" is what GM used in Shop Manuals and in the Master Parts Catalog.
A new/novice member who reads "bell housing" here but reads "clutch housing" in documentation would have difficulty understanding what is being referred to.
As a further confusion, the term "flywheel housing" was the term sometimes used in early pre stovebolt-six years Shop Manuals.
A rose is a rose by any name, this shows the 6 mounting holes for
the clutch housing, four of which are behind the flywheel as Carl
posted:
http://www.pbase.com/dennygraham/image/128167769
DG
Denny G
Sandwich, IL
Thought about it after the post. Working on '49 3600 with 4 speed. Guess the bolts to hold fly wheel are accessible through the opening in rear of clutch housing after the clutch is removed?
Yes they are. Bolts and dowel pins locate the flywheel. After the bolts are out the flywheel may need to be loosened from the crankshaft. A deadblow hammer will get it moving, and it is heavy, and it will mash some fingers. Are you having fun yet? Good news? It will only go on one way. Keeps the timing marks lined up. Keep the 6 volt flywheel with the 6 volt starter. Teeth count is different and the "pitch" is to. Use the same size clutch and presser plate when you need to replace them.
Steve H
Dave that is correct, they are a thin head bolt and if the clutch has never been out they have keepers holding them in pairs. Use a good 6-point socket you do not want to round one off.
Think I got it now. Thanks for all the information. Waiting right now for the sandblaster to call saying the frame is done. Almost done with dirty part and on to putting it back together!!
DaveBP,
Carl.
I had not noticed what GM called that part. The complex English language often calls for clarification during dialog. Since I know this part as a bell housing, and the OP knows it as a clutch housing, it would seem to me that it would be helpful to him and I to make sure that we are talking about the same part. My apologies to ALL of the members (new/novice or otherwise) confused by my misuse of the term bell housing.
Carl
Carl, there is no need to apologize - bell housing is a very commonly used term. The different terms used by GM can confuse some posters and readers - I commented because a new owner/user would most likely (we hope) be looking at a Shop Manual.
Yeah, here in my part of the country, we always called them bell housings. But like the old John Deere 2 cylinders, the parts manuals from the factory use different terms for things that the everyday person would not use.
Another thing, they used terms 50, 60, 70 years ago, that are not used much today.
Bet they didn't have a flash drive, android, or a touchpad back then either.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Where is the emoticon for sarcasm?
