| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 93 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 93 | ........does anyone have the dimensions (ie thickness) for the front cab mount pads ? thanx folks | | | | | Joined: Mar 2003 Posts: 93 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 93 | Brad........thanks very much for the excellent cab diagrams ! ! Altho' I had to laugh at the dimensions given for the distance between the cab and frame rails as 1.67" + .06" -.00" I'll make sure I get my micrometer out as I change the cab mounts. I'm hoping that getting the cab mounts correct will help my hood alignment issues. Thanks again for the excellent info ! ! les | | |
