8 members (Ponchogl, Bill Hanlon, MickeyP, Hotrod Lincoln, Hanks custodian, Otto Skorzeny, Charles in CA, 48ed56pam),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,071 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Recently acquired a rebuilt 216 engine. It has a noticeable valve tick, more than normal. While adjusting the valves I've noticed #5, 6, and 7 intake valves have the noise with 6 the loudest. Adjusting did quiet #2 and a little bit on the ones mentioned.
It's pronounced at idle, cruise, coasting, or downshifting. Under load when starting in higher gears it's nice and quiet and sounds great. As soon as a certain rpm or cruise speed is hit it opens up with the ticking.
Is this a vacuum leak issue? My wipers quit working and was wondering if it is a timing issue. The reason I say that is that it is hard to start even when warm without using the choke. Fresh battery and cables.
I also calculated 20+mpg which may mean it's running lean? It is in a Fleetmaster but I thought these engines regardless of vehicle only get about 14 if your lucky.
Any help appreciated.
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | What rear end gear/transmission are you running?
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Well it's a car with standard 3spd column shifter and 4:11 gears. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If your wiper stopped working, you might have a vacuum leak in that line/system.
Disconnect and plug (or, clamp-off) the vacuum line fitting/hose at the intake manifold.
What procedure did you follow to adjust the valves?
Did you check the valve stem mating surface on the rocker arms? They get worn and then getting a good setting for valve-lash is affected.
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | I disconnected the vacuum line and plugged it. I adjusted per the tech tip on here. I'll have to check for wear where they meet.
I'm still curious as to why the sound disappears when you "load" the engine? Is this an advance/retard issue? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I disconnected the vacuum line and plugged it. . . Do you mean that you removed the vacuum line at the wiper motor and plugged the line? That would be OK. | | |
