4 members (2-Ton, KEVINSKI, dunfire, 1955 1 Series), 110 guests, and 1 robot.
Topics128,196
Posts1,057,395
Members48,471
A pair of 3100 1/2T fenders I had sandblasted revealed matching directional light mounting holes in each fender. Does this mean they are 3800 series fenders? They fit my 1/2T so it doesn't matter to me. Just curious.
Drew
If the holes are below the headlights like those shown on this truck they are most likely off a GMC. These were the factory installed park light on all series of GMC.
https://www.flickr.com/photos/advance-design_parts_co/8130455195/in/set-72157631870734114
If the holes are on top of the fenders like these they were available from several sources including GM as dealer installed accessories.
https://www.flickr.com/photos/advance-design_parts_co/8130556366/in/set-72157631870734114
These could be installed on any truck and would not indicate series.
Brad, They would be similar to the top fender mounted directional lights as per your second pic link. Thank you for the explanation on fitting these as aftermarket and not factory. I'll have to decide now if I'll plug weld the holes or search for a nice set of directional lights. Thanks again.
Drew
Drew,
There are numerous options for you to choose from on these lights from very plain to my personal favorites which look like this.
https://www.flickr.com/photos/advance-design_parts_co/8129481383/in/set-72157631868452754
eBay is probably your best bet if you decide you want a set, lots to choose from with pricing to match, good luck.
