1 members (baldeagle),
36
7
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 68 | Are there any identifying numbers on the frame of a 52 3/4ton GMC? If so where? Oh my truck work pic. have been updated on Flickr & Photo bucket. I think license plates here go by what frame you have. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if there's any number on the frame it'll be the vin# or part of it - I believe some early GMCs had a number stamped on the pass side frame rail toward the front, but what counts is what it says on the title, you should check with the DMV, what's used is more likely the load rating, GVW
Bill | | | | | Joined: Nov 2006 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 68 | I found a number on the pass side on the side of the frame 1'from the radiator it is upside down it is (-16C)what could that be? What I am trying to do is prove to DMV this is a 52 GMC frame. I need to have a new title made. And I want it to be a 52. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There are no serial numbers on a '52 GMC frame. The numbers Bill refers to were last used in the late '40s. | | | | | Joined: Nov 2006 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 68 | I guess there should be no doubt with the running board hangers riveted to the frame and the cab mounts and the emergency brake system. My concern is because I had a title made for my 52-3100 on a 82-S10. DMV said they had to title it a 82 because of the frame.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | . . . with the running boards riveted to the frame . . .
The running boards on a 3/4 ton GMC pickup would be bolted to running board hangers that are riveted to the frame.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Texas recently passed legislation whereby you can title a vehicle as the year it most closely resembles. This was passed in reference to the Fiberglas bodied early Ford replicas but I bet if your truck looks like a '52 it can be titled as such. You might have to go through a title service. | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Another reason to title it before you build it. You need to hire a title service to get it done. Way less hassle. | | |
