4 members (tclederman, Forty9, baldeagle, Wayne67vert), 60 guests, and 11 robots.
Topics128,020
Posts1,055,345
Members48,419
#1049530 08/14/2014 10:39 PM
Are there any identifying numbers on the frame of a 52 3/4ton GMC? If so where? Oh my truck work pic. have been updated on Flickr & Photo bucket. I think license plates here go by what frame you have.
CFG61 #1049536 08/14/2014 11:01 PM
if there's any number on the frame it'll be the vin# or part of it - I believe some early GMCs had a number stamped on the pass side frame rail toward the front, but what counts is what it says on the title, you should check with the DMV, what's used is more likely the load rating, GVW
Flxible #1049553 08/15/2014 12:50 AM
I found a number on the pass side on the side of the frame 1'from the radiator it is upside down it is (-16C)what could that be? What I am trying to do is prove to DMV this is a 52 GMC frame. I need to have a new title made. And I want it to be a 52.
CFG61 #1049583 08/15/2014 3:01 AM
There are no serial numbers on a '52 GMC frame. The numbers Bill refers to were last used in the late '40s.
I guess there should be no doubt with the running board hangers riveted to the frame and the cab mounts and the emergency brake system. My concern is because I had a title made for my 52-3100 on a 82-S10. DMV said they had to title it a 82 because of the frame. frown
CFG61 #1049593 08/15/2014 3:54 AM
. . . with the running boards riveted to the frame . . .
The running boards on a 3/4 ton GMC pickup would be bolted to running board hangers that are riveted to the frame.
CFG61 #1049614 08/15/2014 5:19 AM
Texas recently passed legislation whereby you can title a vehicle as the year it most closely resembles. This was passed in reference to the Fiberglas bodied early Ford replicas but I bet if your truck looks like a '52 it can be titled as such. You might have to go through a title service.
CFG61 #1049651 08/15/2014 1:24 PM
Another reason to title it before you build it. You need to hire a title service to get it done. Way less hassle.
