1 members (Otto Skorzeny), 87 guests, and 2 robots.
Topics128,052
Posts1,055,717
#1048184 08/09/2014 6:55 PM
I opened up the 216 I obtained for my '46 to clean out the sludge and it's cleaning up nicely. One little problem...the screen on the oil pump has a few holes. Not huge, just the little squares turning into little rectangles. And just a few of them.
The question: can I use it like that, or should I track down another one?
H Online: Content
Where are those little "lost" pieces going? Maybe right through the pump and into the bearings? I'd suggest fabricating a new strainer screen of some type. I've had pretty good luck using pierced sheet metal that's available on Ebay with small round holes, maybe 1/16" diameter or so, and forming/silver soldering it into a strainer.
This may be of assistance when you reassemble your pump.
Harold
Oil Pump Exploded View
Harold
Are there breaks in the wire, or are the gaps just different in shape?
52Carl, it looks like breaks in the wire. I took it off to clean because it was caked with sludge. It was a running engine that was pulled out of the truck and still warm when I hauled it home, but I know it will work harder than it has in a long time when I get it in my truck so I want to do this right. I will check the screen in my old engine to see if it is in better shape.
The inside of my 235 looks beautiful. Except for the #4 rod bearing and crank journal. I used the screen out of that one because it looks like new.
