3 members (RLB, Oswald, GRNHydra),
86
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've been wanting to add a 3rd brake light for some time now, scored an original Hollywood Accessories Safty-Lite A while back off Ebay. Finally got around to installing it, plus a set of leds under the tailgate. Hopefully, now people following me will get the message when I'm slowing down/stopping!
Bill Burmeister | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | Me too! I like yours LONGBOX55.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | So far, it seems to be working very well. I've noticed folks staying further back from me at stops. I'm going to chalk this one up as a good investment and addition to the truck. In addition, I didn't mention this in my earlier post, but I did do a slight modification to the Safty-Lite. Instead of the single 1156 bulb that it came with, I have installed 60 leds (6 strips with 10 leds apiece) to get more even and brighter illumination. The strips I used are made by Alpena, and are very bright. The strip under the tailgate is also made by Alpena. If anyone is interested to see how it's setup, I can pull the cover and lens and get a pic or two of it.
Bill Burmeister | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | I have the same ( "S T O P" Light, which has been kicking around for years in my Parts Pile...been thinking of adding it to the rear top on mine too.
Every little bit helps! Especially with all the 'texting' SUV people now.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | . If anyone is interested to see how it's setup, I can pull the cover and lens and get a pic or two of it. Interested Would like to see what holds the strips in place Thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Leds with lens removed. The strips have a very strong 3M adhesive on the backside, just made sure the surface was perfectly clean before I put them in. Once they were stuck down, they were stuck solid. I have the run staggered, with 3 of them wired to the left, 3 to the right. Here they are on.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thank you
That worked out well for that stop light, and looks great.
I'm going to convert an old second set of lights on my truck but they are round.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The leds I used are made to be able to be cut to size, and they do carry them in their regular output line in smaller lengths. I sourced mine from Autozone and Advance Auto.
