6 members (Donf, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost), 120 guests, and 1 robot.
Topics128,056
Posts1,055,799
Five year slog and almost there. Two shake-out issues I could really do with some advice on. First up, steering box - manual - it's the original and there seems like there's more play in it than I remember, like holding the steering wheel - original - there's like maybe 2 or 3 inches either side. Even as I write this I'm thinking someone's gonna say dude....you serious!? I think I could get used to it like I don't notice it. Like lite coke? Okay ,so on the chance I might have to replace, what's the options. Like for like? Or is the a performance upgrade alternative by one of the aftermarket brands?
(Monitor's note: Please make a separate post for different questions. Please post electrical questions in the Electrical Bay.)
bustagut,
What make/year/model truck?
Have you gone through the Shop Manual procedure for adjusting the steering box? I put it off for years, but when I finally did the adjustments, the result was remarkably good.
Depending on your skill/tool level, you could rebuild your steering box. Or, you could have it rebuilt (Rockauto.com provides that service for many makes/years/models). From/in the UK ???
Turnsignal switch "as per orginal" - see first question.
Tim.
Should have said. 63 C20.
Didn't know box could be adjusted.
Rockauto - pretty good outfit, have used them lots.
What is, roughly, the allowable play?
I do not know about 63 C20.
Check the 1963 Shop Manual for adjustment and play (they should be described). The play you describe seem to be a lot of play.
Rockauto uses Lares Corp for rebuilding. Rockauto does this for a slightly lower price than Lares and much lower shipping cost (for 1947-55).
I bring this up at all the steering questions,
http://chevy.oldcarmanualproject.com/booklets/52mts20/5220mts01.htm
Almost all manual gear boxes are the same. Just read through and you will see how they adjust, yours will be very close to the same.
Joe
Okay. Now I have some food for thought.
Many thanks, Chris.
You might also find some of these other booklets helpful,
http://chevy.oldcarmanualproject.com/booklets/index.htm
joe
