0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | Posting this as an FYI for others..... I bought a replacement W-1 carb for my '46. When I installed it I used a new carb insulator. The new insulator was a hard black plastic while my old insulator was some type of composite. The black plastic was too tight on the manifold so I filed it wider to fit snugly. Put on the new carb and could barely keep the engine running - needed to choke and run at high rpms. Over a period of days kept fiddling with it but it would not run properly. I figured I had a bad rebuilt carb, swapped the old one back and ran a bit better but still would not idle, it needed to be choked and would only run at a fast rpm - otherwise it would die. After several days of wondering what I did to screw things up, more adjusting the carb, etc. I finally remembered the insulator. I swapped that back and the engine runs fine. I never would have believed that that dumb bit of plastic would make such a HUGE difference in how the truck ran, it was night and day. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Daves46pu, This topic was described in a recent post. Most likely you had a vacuum leak on the side of the insulator that did not have a gasket, usually the bottom of the insulator. A gasket on both sides of the insulator would most likely eliminate a vacuum leak. Also, the gasket between the insulator and the carburetor should have little "cut-outs" that must be aligned with a hole in the base of the carburetor. | | |
