10 members (Gray_Ghost, Nick in Manitou, Gdads51, Jon G, Otto Skorzeny, Hotrod Lincoln, walter74, LAROKE, 2 invisible), 107 guests, and 3 robots.
Topics128,131
Posts1,056,372
Members48,441
#1047472 08/06/2014 4:51 PM
Does one exist?
What exactly are you meaning by "airbag kit"? If you're looking for the lad leveler type for a truck, Brother's used to have one for the '55-'59, and I would think that one for any leaf spring truck could be adapted to fit.
If you're looking for the Passenger car/Mini-truck version that can be dropped to "lay frame", you're not going to find one that will work with the stock type suspension.
Bill Burmeister
thanks, im not sure if I want it to lay frame, but I do want it to be lowered, I know they sell lowering leafs, or monoleafs, just looking for the best way to lower the truck 5-7 inches. Any suggestions?
Not sure there is such a thing. i.e. a model specific kit for this truck,most 'bag' kits are aimed at aftermarket front IFS and rear 4-link suspension set-ups.
Most kits for leaf spring set ups as far as I can work out lean more towards a 'helper' spring for overload situations.
Lowering 5-7" might get things a bit close to the chassis on a stock front beam/rear axle too.
You could do worse than give Sid a call,he'll steer you in the right direction.
More pix on Flickr.
I went with Sid for mine. 4" drop in front and used lower blocks in back for a 3" drop. You can also pull a few leaf springs out for a couple more inches, but that is up to you.
