5 members (FAST55, Phak1, Gib70, DadsFirstPickup, Bill Hanlon), 135 guests, and 6 robots.
Topics128,108
Posts1,056,231
Members48,436
I finally have my 51 one the road only to find out that the 4 speed transmission whines and vibrates like crazy! I know that rebuild kits are available, but what about replacement gears. Does anyone know a source for parts for a tranny rebuild?
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
Thanks. I'll see if that is theright transmission.
The transmission in your truck unless modified will be the SM 420 which was offered from 1948-67. There is a member here who completely rebuilt his with NOS parts and they are available. Novak rebuilds a lot of these transmissions and has upgrades available to make them bulletproof. Here is a step by step slide show of the rebuild process.
https://www.flickr.com/photos/advance-design_parts_co/sets/72157632620943718/
Brad,
Do you know the manufacturer and model number for the 1947 and earlier (41/42-47, I think) 4-speed transmission?
In another thread: "Before 1947 1/2 GM used the non-synchronized 4 speed SM420, as a new feature in mid 1947 (about May)the SM420 added the synchronized 4 speed, but still called an SM420."
SM420's seldom cause vibration or noise. It is much more likely you need pinion bearings, torque tube bushings, and rear U' joint yoke.
My Blog
I will look Tim, I have lots of AD stuff but not as much on the 41-46 models.
