3 members (DaveV, Phak1, TUTS 59), 223 guests, and 2 robots.
Topics128,162
Posts1,056,942
Members48,458
I have a '54 chevy 4 speed trans I got for almost nothing, but the gear shift lever is missing. There is a junk truck on a friends farm that is rotted away gone, total trash almost but the trans is in it, but it's up on a hill, can't get to it etc. I just want to get the gear shift lever. how does it come out?
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
You push down on the tower cap and rotate it slightly counter clockwise. It will then release. The shop manual shows a tool. I use a mokey wrench on its side.
1951 1 Ton Completed
Push down on retainer and turn
...pic...
...click...
I think it's ccw
Junkyard.... might need some penetrating oil to loosen up the retainer
counterclockwise then lift it up I guess? Thanks!!!Can I use a crescent wrench on it'side?
HOLY COW! that video clip is perfect. Thanks guys!! this site is awesome! I am trying to make my own side by side out of my extra 248 I6, my 4 speed, and one of my extra rears, and my extra steering column......... It will be one tough mule (if I actually get it made.
when I took mine apart for inspection, I used a roll of electrical tape, slid it down the shaft, pushed and turned ccw. worked like a charm cause the cardboard middle of the tape roll kinda 'gripped' onto the retainer.
